Conversion kit
Wanted-conversion kit for '90 240sx from automatic to manual; if there is any places that sell all the parts for this, or there is a parts guide someone could redirect me too that would be great. If anyone has any information that could help out plz pm me. Thanks
-Brian
LOOK IN THE FOR SALE THREADS!! and go to JDM shops, and junk yards!!
No kit. You need a walk through. I think there’s one in the FAQ. It tells you all the parts you need, and start surfing the FS section.
u need
tranny, clutch, flywheel, all the bolts to bolt it on. tranny plate.tranny mount
clutch master and slave , clutch hard line, clutch soft line,
clutch pedal brake pedal , speed sensor, and some wiring. manual ecu if u want.
I’ve got a perfect 5spd tranny for you if your gonna start parting everything together.
$100 and its yours, includes the throw out bearing, pitch fork, and fork springs.
i’ve also got a stage 1 centerforce clutch, grabs hard, and even harder at higher rpms. Has 1000k on it, and comes with the flywheel.
$220 for the clutch/pressure plate, and flywheel (all bolts included aswell)
