What is the best way to cut the gas line underneath the car? I can’t get a pipe cutter in there so its so tight. I have a small rusted area and I was to replace that section but I’m not sure the best way to cut it out. I dont know what I could fit in there. Even a hacksaw would be hard to fit.
assuming there is no gas around, and you still have a dude standing around with a fire extinguisher, i would say use a dremel cutting tool. very small and would make quick work of the line.
Pull down on the lines a bit to help get a pipe tool in there. THere is some mini ones available.
Man, are you planning to cut them whre they are??? No way!!! Disconnect tha plastic clips that are bolted to the body, all way along, they all then go down abt 10 cm! Keep in mind when you saw thm sparks can light id up:(( Another person with fire extngsher would help) 360 pipe cutter would be best. And have tha plugs ready, as the gas is gonna flow from both ends
