Just becasue the battery has 12 and a half volts doesnt mean its good. i see batterys all the time at work that have proper voltage but next to no amperage, which is what you need to start a vehicle.
Also check to make sure the fuel pump is running.
-A simple way to test the first scenario woul be jump start the car.
A good way to test the second screnario is open up the fuel fill cap, turn the key to run and listen for the pump.
While it was running with me giving gas, if I let go fo the gas slowly the idle would come down to about 200-250rpm and it would stay running there for a bit.
Eventually after a while it would die.
It’s a MAF setup and i have no way to test the shit or the crank/cam sensors.
take off the alternator belt off, sounds like it could be seized or close to being seized. If the car can start and idle for a bit without it then its probably the alternator.
You said it idled then died on you, if theirs a air leak in the mani the lack of pressure will cause the engine to stall. You said you replaced your starter, so why would it not be possible that coil isn’t giving any spark.
Don’t star track me when I’m trying to help and you would think after so many posts you would learn to but it in the right section.
I said it idled at 200-250rpm - that is nowhere near normal. And the only reason it did that was because there was enough juice in the battery to keep it going.
We (CAA technician and I) saw it with the multimeter. With throttle open and rpm 2000+ voltage was 14v. Moment he let go throttle, RPM came down and so did the voltage.
As it was around 200rpm or so you can see the voltage dropping slowly and within 5-10sec it dipped well below 11 at which point it just died.
I never said I replaced the starter; we replaced the alternator Aug 9th.
I appreciate your input and I’m sorry if you felt patronized.
