So I got the unit and all kinds of sensors and stuff and followed the guide on nico for the most part but i got a few questions for the experts on here.
1- Do I still need the full cold motor or is it garbage?
2- The climate control in the car now has a sub harness that connects to the full cold motor, full cold motor relay, some kind of micro switch near gas pedal.
I removed this subharness and dcc still seems to work fine.
3- Is the sensor that mounts near the fan resistor needed? People call it a thermo amp?
4- When the dcc is working and I press auto it always turns on the a/c even if the temp is set to the hottest.
5- The mix motor mount to where the cable use to be but in it’s default position should it hold the air box to hot or cold?
Thanks guys
