disabling ABS?
i know on some cars you can disable the ABS system by unhooking the sensor at one of the wheels. can this be done on the S13 or is there any other way to do it?
Just rip out anything ABS related. Mmmmmm weight savings. Let the FSM be your guide.
you can pull the fuse i think too.
what about the actuator, can i rip that out and just mate up both ends of the line?
just take the fuse out, its not worth the effort to remove it physically
Or you can just install D2 Coilovers and wonder why the fcuk it doesn’t work.
The main ABS hydraulic unit is very heavy and you can drop maybe 30lbs by pulling out all the ABS stuff.
