Just sharing, I made a couple minor changes this week. I powdercoated the little front braces this cool new translucent color i recieved called “Ebony Chrome.” I thought the annodized aluminum stood out wayyy to much over the dark body color.
I also pulled my fog lights out (since I never use them), enlarged my brake ducts, and cut up a mesh grill from my original bumper, plastic welded the mesh in to fill the voids. I put the splitters on for the picture while i try to sell them…i don’t think i like 'em.
Also threw a 3M clear bra on… as everybody knows…that was a bitch.
klemann will do anything to get me to fill a hole :gay:
Denton: The plastic welder i have actually melts the plastic as I add a filler rod of similar plastic, just like regular welding (minus shielding gases)
ghettostyleTA: Clear bra is super easy over surfaces that are conmplex or have complex curves. It doesn’t stretch very well, so you usually need to make relief cuts or chose how to cut your 3M pieces (if you don’t buy them pre cut). Basically use lots of Alcohol/water mix to keep the adhesive lubricated until you get it posistioned. Squeegie the air bubbles out and, set it…and forget it.
