#1 added support with the bumper support gone. And from wind “flapping” at hi speeds. That Ive seen on cars going down the track.
#2 The GP rear is like a ass dragging snow plow for the air under the car. Hopfully better MPG, trap speed. better everywere I see.
The support frame I made. All hand tools, cheap light weight materials for lowes.
3/4x3/4 alum angle iron. a 1/8x1 bar. And some weied thin alum U channel 1/2x3/8 I belive its panel edging? Cut the 30" I was going to wedge it behind the outer, and infront of the center L tap on the bumper. But it bend over my knee nice [:)]. So I just gave it the nice curve that matched the arc of the bumper.
Top support, is 3/4 x 3/4 alum angle, going off the outer muffler bolts. And itjust happends to be on the same plan as the pinch weld for the trunk floor and the spare tire wheel. So I got some 6-32 nut/bolts on the weld seam in the middle.
Then I made some conection brakets that come out really nice.
I cut them out so after I bent the angle they touched for added support. Sence I can’t weld alum. Plua this is low buget, so Im just useing 6-32 machine screws for harwear, and #6 sheet metal scews for the skin.
mad a cender brace with the curve of the skin, and a ataching bar.
Than made a carboarded tempate for the skin. And traced it on some shitty acrillic plasitc I bought. I knew acrillic is the shittiest sheet plastic for working with but it was so cheap ($8?) 48x48. over 48x36 .025 alum that was $60. I cut it with my jigsaw at hi speed, and a super fine blade. And suported it well, and it still started cracking and spider web cracking all over. I bend it into shape just to test fit it better. But drilling holes it will crack all the hell. Im got get some softer polycarconate tomarrow and make the rest of the skins.
then center main skin just sitting there
what the air seeing under the car
Im gona make a skin peice for over the tip cutouts. The a outer skin for the sides to the wheel wells. tommorw after work.
Will track test it for back half gains if I have time.
discuss.
will it create lift and make the rear unsafe?
or will less air drag under the car, give it the wing profile effect and more down force (never gone to school on this I dono?)
