Doesn't sound right
Give a listen to my exhaust and tell me what the random “blowing” sound is coming from exhaust. You can hear it better near the end of the clip. Something is definitely not right.
where exactly is the sound coming from? fron of the car? engine bay? rear end?
if thats still the stock exhaust, your car is fine. Mine did that ALL the time. Seems like its something with the factory system. Aftermarket ones never make that noise, plus you have the same mods that my car did it seems.
kinda sounds like a misfire at idle
sounds like a build up of pressure being released. some sort of resonance that causes it to pop.
in the clip you mostly hear engine noise from the front of the car. I was recording by the exhaust.
hmmm i wonder if maybe i should go highflow or catless downpipe.
just do the whole exhaust…catless dp seems like the way to go…
sounds like no backpressure and its backfiring a little
Sounds like backfire/misfire to me.
new plugs seem to have fixed the problem. i’ll know tonight after i get on it some and tweak it a bit.
