When dropping the engine from the bottom, some people say just disconnect the brake lines, and some people say remove the whole ABS/master cylinder assembly.
My specific question is, with TCS, can you just disconnect the brake lines? Because it doesn’t look like the engine will clear the traction control valve assembly that is below the ABS unit.
