so i have four wholes in various spots in my apartment, all of which were created due to intoxication, there is one the size of a fist, and the other three are the size of well me 6’1 190 (dont even ask)
so my question how in the hell do i fix these, the bigger holes are between the studs and the smaller one is right next to them so any advice would be helpful
cut it out the chunk from stud to stud, put a new piece in(mounting it to the stud on each side. then spackel(?spelling) and sand away. should be fine.
lol the hole is about 2 foot by 5 foot
pics up soon
[/quote]
I made one of those in the dorms. I filled the wall full of pizza boxes, beer cans, newspaper, pizza crust, ramen noodle wrappers and shit. Mudded over it and it looked normal… id hate to be the person that leaned up against it for the first time tho.
Anyway you need to go to Home Depot and get:
1 1/2" drywall screws
A drill motor with a bit a tad smaller then the screw body
several 2x4’s or just 1 to start
a saw to cut the 2x4’s (Hapbor Freight will have a cheap hand saw)
at least a gallonof spackling compound
wide spackle knife
several window screen style drywall sanding sheets
You will have to span the hole (ON THE INSIDE OF THE WALL) with the 2x4.
You cut the 2x4 about 12" longer then the width of the hole.
Put the 2X4 in the hole vertically, rotate it horzontally so it spans the hole on the inside of the wall.
Hold it up against the wall and drill a hole through the wall and into the 2X4 (dont be smart and skip the drilling, you will be sorry)
Screw the 2X4 to the wall through the hole u just made.
REpeat on other side.
Each 2X4 needs at least 4 screws in each side.
You can repeat this till you fashion a makeshift wood backing wall behind the broken wall.
It would be best to cut all the pieces first and stack them inside the wall because you wont be able to rotate them once the hole gets smaller… you can sill slip them in if they are not tool long. Put a screw in the center to act as a a handle.
You can then cut a new piece of sheetrock to screw to your wood backing and fill the hole shape.
strokingnova i’m right down the street from ya…i can help ya out this weekend if ya need a hand
[/quote]
sounds good, me and my friend jeremy are doing it tomorrow night, we will be drinking beer and hoping not to loose a hand to a circular saw and im having people over so either way it will be a good time, bring who ever you like if your interested
lol, this thread reminds me of one time me and my buddy were playing nhl hitz on his xbox in his basement. we were playing on a team against the computer, and it went into overtime :ohnoes: it was an intense OT session, and we finaly scored with three seconds left to win the game We both jumped up in the air and as i was jumping he shoved me hard into the wall and i went head first into it and put my forehead through the drywall. so we just moved his moms painting over the hole and hoped his parents wouldnt notice when they came down :snky: it didnt work :biglaugh:
