e-Fan question
what is a better set-up to go wit?
a pusher or puller.
that is all, thanks
I would say it would depend on where you have more room.
My M3 e-fan is in front of the rad and I’ve never had any probs.
Corvette has dual fans post rad also never any probs either.
IIRC puller is better
Pull.
Pull
push/pull can both be the same efficency… its just a packaging thing, and making sure the fan you are using is desinged to operate that way…
i saw a car using a pusher fan as a puller, and the kid couldnt figure out why he was overheating… he thought he could just switch the polarity and spin it the other way… but the blades were angled wrong
on 240’s (esp s13’s) go puller they have cooling issues, of course with an rb25 you should go puller anyways bc of your HUGE FMIC you should have on your car, or if you are to upgrade to one if you have stock smic.
^word sounds good. seems like my fan works but not enough(pusher)
good info on the different types of fan, i thought u could just reverse it.
the dual fan setup from a taurus is 2100CFM IIRC on the high setting. They are two speed fans and can be found at any junkyard.
edit: they are puller fans.
