e-test Results help! updated pics
so i failed my e-test twice and here are the results…
Car: 1989 Nissan 240sx
Mods: Bone Stock
First Test
New plugs and wires
New air filter
oil changed
ASM2525 TEST
__________Limit___Reading___Result
HC ppm-------64--------639----------FAIL
CO%----------0.35------0.56---------FAIL
NO ppm-------727------1025---------FAIL
Second Test
New cat
New O2 sensor
ASM2525 TEST
HC ppm-------64--------548----------FAIL
CO%----------0.35------0.53---------FAIL
NO ppm-------727------232---------PASS!!!
ASM2525 TEST
Second Test
New cat
New O2 sensor
ASM2525 TEST
NO ppm-------727------232---------PASS!!![/quote]
lol…your HC is super high, does the CAT work?, turn the fuel pressure back to stock so your running 14.7:1 AFR
:fnf2:
willx changed a lot of shit. new cat btw, new o2,new plugs, new wires,got his egr connected back, and booted the car before the test.
he even failed at my shop, where the guy just let the probe hanging on the tail pipe, not even full in. still fail.
wehne you fail hc it means you arent burning all your fuel,
change plugs, run 87 or 89, change coil, change distrubitor, etc
slide him a 50 and test another car that will pass as yours?
i donno if neone is going to risk doing that nemore…
they have been really tight on these stuffs lately…
new cat $200 installed
new o2 like what 75 installed?,
new plugs, new wires, another what 70 bucks?
got his egr connected back dont know
if ur almost near $400 just pay $400 cause then u get a free pass
have the guy to give u a condtional pass
if u a not selling the car
Try exactly what DTS said and some “Guaranteed to pass” from Canadian Tire. Check timing, oil, intake and other general items looking for anything suspect.
I’d say don’t pay for a pass.
high HC levels = unburnt hydrocarbons… you are running a bit too rich… usually a new O2 sensor fixes that, but since you already got that, I don’t know what else it could be…
The repairs have to be done at a shop with a certified emission repair tech for you to get a conditional pass. The limit is $450 not $400. What type of cat did you put on? Aftermarket cats are garbage.
tune itttttt
^^^ yup… after failing once, my bro went outside to the parking lot and used his V-AFC to pull back so much fuel on his Prelude that he could barely idle… hey tested him again and he passed no prob. :lol:
change ur dizzy cap and rotor
thanks for the input so far guys! But i wish i could get a condictional pass. I need the car register under my name. Anyways i tried the “Guaranteed to pass” on my first test and it did not work at all. Too bad i threw out the receipt or i could got something back from them. I think My timing is advance. When i look at my distributor, it looks like it’s mounted all the way to the left. I’ll try to take some pics of what i mean. Would advacing your timing cause you to run too rich?
You can only get a Conditional for your renewal, you cant get it when the ownership is changing names
http://img292.imageshack.us/img292/2116/img3531oa5.jpg http://img244.imageshack.us/img244/2655/img3532jp4.jpg
here’s a pics of what i’m talking about… I think the timing on the distributor is advance causing it to run rich. Just earlier today i heard the car back fire on idle with a stock exhuast.
Most likely, u have an exhaust leak pre 02 causing the sensor to read improper readings thinking it needs more fuel! check to see for ne cracks on the exhaust mani b4 the 02! if u get rid of CO, u basically get rid of HC at the same time! try the ignition timing too! retard it a bit to help lower combustion chamber temperatures causing NOx. hopes this helps! If ur really worried, add about 1-2L of methyl hydrate to a 1/4 tank and run the car around town for about 10 mins! U should pass with flying colours!
i just did my etest today and i’m pretty happy with the results. check them out.
nothing was changed before the test. and i have a blown o2 sensor.
ASM2525 TEST
              Limit     Reading
HC ppm 64 14
CO% 0.35 0.08
NO ppm 485 53
CURB IDLE TEST
              Limit     Reading
HC ppm 200 20
CO% 1.00 0.01
