was wondering if someone can tell me the right way to turn the ecu dial to get codes from it. ive had ppl tell me to turn it counter clockwise, others told me to turn it clock wise. and then i was also told to turn it all the way clockwise, then turn it back all the way counter clockwise. and do i do this with the ignition off or do i do it with the power on and motor not running? If anyone can help me out with the correct method of doing this it would be much apprecaited! thanks in advace!
pretty sure its clockwise. Theres only one way to do it so if you have it all the way to one side and you dont get codes turn it the other way and you will get it. Turn it when ignition is off, once ign is on codes will flash on the ECU
SEARCH THERE IS DIFFERENT MODES FOR SDIFFERENT CODES. GO NICO OR KA-T
