i saw so some different model # ecu will fit s13 sr20det. anyone know what the different between them??
will ecu model #62 fit in a 98 blacktop s13?? thanks!
Nope
ECU 62 is for a 5spd S13 Red Top, ECU 63 is for an Automatic S13 Red Top.
ECU E5 is for a 5spd S13 Black Top.
ECU K5 is for the 5spd S14 Blacktop.
S14 and S15 engines have Variable Valve Timing.
S13’s don’t.
I have a more complete list somewhere, but I couldn’t find it with a quick look.
I have used #63 (auto) with a Redtop 5 speed without issues.
I see no reason why a #62 wouldn’t work with an early S13 Blacktop ( I think only changes were emission releted and minor).
It will not work with the 1997-8 S13 Type X blacktops.
How do you tell what your your motor is? Good question! On some I have seen a year written in marker pen or paint marker on the back of the block. Split the engine and trans, and look behind the adapter plate.
-Martin.
but i just install a #62 ecu with my 98 blacktop. it will work.
Yes if its a S13 blacktop
can ECU D4 can b used on S14 Black top? and there is a WV on the sticker…
