EGR and AIR delete on an LT1. OBD1
Will my car still pass inspection with “race headers?”
Does it even matter since it’s from 94?
Thanks
Gus
Thanks
Gus
you’re going to have to do something about that check engine light
+1.
plus i’m assuming your not running any cats either?
just find someone to overlook that stuff… obI doesnt have to worry about the crap taht obII as far as inspectiosn go. :rant:
Theres a service bulletin for the B bodies anyways that allows you to do away with the air pump, GM even had a sticker for California owners to stick on their car
I got a place to “over look” a few things.
I figured I’d get the check engine light, but will it make my car run like shit, or is it just a light?
Assuming I need to get a tune…
Because a cam/gear drive will be going in.
well if your getting that done i would get a tune after the cam install and you might need to have your speedo recalibrated after the gear install, if your car is ne thing like mine you can just have the codes tuned out of the ecu and you won’t get that light ne more.
