Eight-way adjustable wheels?
http://www.blogcdn.com/www.autoblog.com/media/2009/03/daws_camber6.jpg
When Charles Pyott considered the possibility of on-the-fly adjustable camber, he looked at motorcycles, the human foot and cars like the Mercedes F400 Carving and the BMW Clever. What he came up with isn’t something you’ll find on any of them: the Dynamically Augmenting Wheel System, or DAWS.
Instead of making a wheel that adjusts its angle, Pyott created a wheel split into eight sections that can slide laterally on a special hub and bearing. That means the wheels can have an effective camber change without altering their angle relative to the car, and you keep the vehicle’s entire footprint in contact with the ground. Not mentioned, it could also be used to alter the car’s track.
More weird pics:
Interesting concept… except for the forces put onto that ring which controls the angle of the wheel segments would be INSANE! What will it be made of, diamond?
I’d love to see a video of it actually installed on a car.
Very weird. I would also like to see this in action.
expensive tiressssssssssssssssssss here i come.
but can they drill down to the center of the earth?
Wow… that is a really coll concept. I had an idea similar to this a year back but like most of my crazy tinfoil hat ideas, I just kept it to myself lol.
That’s wild.
Maybe I’m looking at it crosseyed, but that doesn’t change the camber angle? Just pushes the contact patch out further?
That’s essentially what increasing the camber angle is doing on a normal wheel/tire.
Thats what I was thinking. How do you change camber and keep the entire contact patch on the ground if the road is flat.
I sense a fail…
Why cant you just make the upper control arms to be moved by hydraulic or electric actuators?
I thought it had more to do with maintaining a contact patch as body roll changes the angle between the car and the ground. This kind of shit’s right up newman’s alley. I on the other hand am not so great with statics. Waiting…
Hmm, that’s a good point. I wonder if these things have any flex to them.
It’s all about moving the center of gravity.
Wow, the tires seem like they would be way out of balance at speed…kinda like the “tweel”
Nah, dA of rotational CS about hub center is 0
And has virtually zero effect on steering and little effect on grip… like real camber. That’s what made the Mercedes concept (in 2001?) that they reference so capable, it actually had dynamic camber.
False. Moving the CG allows both wheels to receive a more even split of normal load, which is the best possible thing you can do for grip.
I know wheel balance has a lot to do with side to side weight difference, but i see what is being said. As long as movement (weight transfer) is the same on each side of the wheel to counteract.
Right?
If a tire had a linear relationship between lateral grip and normal load, then loading tires equally wouldn’t matter, however, since grip vs normal is a logarithmic function, you want to minimize the delta of the load that each tire sees, ESPECIALLY in a side to side case, because tire widths are the same (unless you’re always turning one way). Increasing camber will ensure that the contact patch is maximized, but even dynamic camber won’t change the amount of normal load that the tire on the short side of the turning arc sees (decreasing as lateral load increases) to an appreciable degree.
The only way to really do that is by moving the center of gravity in a direction opposite the lateral loading vector (i.e. towards the centerpoint of the turning arc)
And, basically… there will be some loading on the hub that wasn’t there before, but the overall BALANCE of the wheel is the same.
