Hey all…
I’ve got a few small electrical issues which seems to be from the past owners awesome home install of a remote starter. There are a few things that are just messed, but need to be fixed before I can get it safetied and road legal…
Problem #1:
There is no neutral safety switch. I can start the car in gear, or out of gear, does not matter. Also doesn’t matter if clutch is engaged or not. I remeber when I got it home he had some wierd setup with like infrared lights on the shift knob, which told the remote starter it was in neutral, and I’m assuming because he had that he jumped the neutral safety switch somewhere. Where do the wires from the neutral safety switch go, what color are they, ect.
Problem #2:
Windshield wipers… I’ve basically figured out the main problem, the wiper motor is not getting any power whatsoever to wiper motor terminal 2, top middle. When I plug a power wire into there, everything works fine, intermittent, slow, fast, washer, ect. In the FSM it says power comes from fuse block 16 to the terminal, there is power at the fuse block 16, but none at the terminal… What color would these wires be? Where could I wire up a temp solution easily where power would only be supplied when ignition is on…
Problem #3:
My Parking Brake Light does not come off… I can take off the console and push in the switch, and the light on the dash visibly dims when I do that, but it does not come off, it just dims, and it’s the only light on the dash that does dim. This one isn’t too big of a deal, but I’d like it fixed…
Problem #4:
I’m getting codes 82 and 34, crank position sensor and knock sensor respectively. Is there any way I can test these, the cps looks freaking impossible to get at at the back of the motor, as does the knock sensor…
Any help is very much appreciated. Thanks so much!
