electric fan question
Im wiring an electric fan in my s13…
can i not just splice into or use the wires running to the ac condensor fan?
i know theres writeups on using that relay… but… u still have to buy or use a thermostatic switch… is the condensor fan not on a thermostatic switch?
ty…
Although I don’t own a Nissan, I think if you were to wire it into the condensor fan, you have to know when the fan comes on.
It might be at high temps (210+) or even when the a/c button is pressed.
I would look into wiring it into a relay, and just purchasing a thermo sensor to activate the fans.
Or you can wire it up all the time if you prefer.
i also trying to wire a altima fan from junkyard
but i find out i only can fit one… too big. to fit 2…
i am wondering which one pull more air A/C fan or the normal Fan.
thanks for reading
To fit the altima fans all you have to do is trim both sides of the bracket about a mm on each side.
When putting it in, remove your top coolant hose from the rad and it should slide straight in.
i trim both side still didn’t fit… bec my car is a pulsar and the FMIC pip is in the way…anyway… yea… i will just pick one of them and zip it.
watch you dont cut off TOOOO much tho… or the fan centers will rub holes in your rad.
this is what happend to me… 3 times.
