so i know some of you guys are REALLY good at what you do, my buddy has just turboed his 2008 Scion TC. everything looks legit.
so here is the issue…
the vehicle has Electronic throttle (no throttle cable) and when you give it gas it does nothing and if it does somthing its VERY little… when the vehicle sits for a few hours and started up it can be revved once then after it goes back to its wacky ways its been acting.
the vacuum line for the distribution block is tapped of the EVAP and the SSQV Bov is tight so its not open at idle. there is 0 leaks anywhere.
he is using a fujitsu intake for the MAF so its the correct direction.
both O2 sensors are hooked up. one in the stock location and the other tapped on the downpipe about a foor from the turbo.
the car runs and idles just no revving. he also threw a check engine and maintence required light.
DOES ANY ONE have a clue why it wont let him rev his car up? Please if you could get back ASAP that would be wonderful.
Thanks
Andrew
