building a sbc, looking for best cam, not sure if its flat tappet or hyd…
i know the obvious is to build a 383, but curious to see what i can squeeze out of a stock 350
money is not a concern, this thing can take the next 2yrs to build if i want…
looking for streetable, but large amount of power…
probably run a th400, and a corvette irs…or some form…all the specs after the motor will be dealt with when i get there…
i was 1st thinking of ripping the rotary out of the 7, but than, i got to thinking, that doesnt show enough character, so im looking for something one of a kind…found a few things that caught my eye, but i havent made a decision yet…
i was thinking along the lines of the olds 403,i had…
edelbrock performer rpm series cams and lifters -> thunder series?
highrise aluminum intake, holley 4barrel
bored .30 over, etc etc
rebuild will be done by me, i can have the motor apart in under 2hrs, milling and what not will be done when i get there…
well there are lotsa combos…I run world product heads ,weiand teamG manifold, and a B/G speed demon carb.What kinda numbers are you looking for? I am assuming hp numbers arent as important to you as torque is ,commin from the 403 which is lotsa tourqe,low hp.
buy my 383 shortblock. 2500 bucks, all forged 1600 miles on it, just about brand new, still see crosshatching on the bores. needs cam heads oil pan etc etc to run but i have a good cam/oil pan for it i can throw in for abit more $$$$ Solid 400whp car, mid 11’s at teh strip. mid 10’s on 150 shot
