PM me when you guys are ready give me a week or two notice so i can make you a fresh set.
I’m readdy when ever man need pics? Text me 289 257 0400
OK I will make a set for you this weekend will text you when its ready.
Bump. I have an other set ready to go.
Hey man really interested in a set, gimme a call located in pickering and my name is mike 905 76seven 24two1
I have 1 set ready to go if anyone is interested.
Just some advice for anyone looking to install one of these. the best thing to do is to always cut out the old rust before installing if you can and want to. the reason is as the old rail rusts apart inside the new frame rail it will leave behind all the old rust. once water sokes into this rust its harder to dry and can rust the new rails out faster. it will still take many years but for best results paint then under-cote the inside of the new rails cut the old rails out leaving enough to weld to and then enjoy that should last longer then the life of the car.
An other tip for just placing them over the old rails you can also use a jack to jack them into place to get an even tighter fit plus it stops it from moving around when welding.
C clamps work great for squishing the tops of the rails to the frame rail to get a nice tight fit.
Do you have one available? I need it ASAP.
What size gauge are the frame rail?
frame rails are all 16 gauge steel with a second 16 gauge reinforcement plate to lift the car with. It is the same thickness of steel that comes from the factory.
---------- Post added at 10:24 AM ---------- Previous post was at 10:15 AM ----------
I have a new design of frame rails available now. The edges are tight and clean and the whole design is far more accurate. I also allowed for extra space between the reinforcement plate to allow of easier fitment over damaged rails. All rails will come oiled so they wont rust if left for a long period of time.
The best way to get a hold of me is by PM as I may not always see this page pop up.
might need a set. you’ve been pm’d.
I need one, driver front. Do you still make these?
Bump. I will post in this thread if I ever stop making them.
i have 2 drivers side and 1 passenger side patch in stock now for those who want a quick easy and cheep fix for your s13s.
this may fit coups as well.
bring your car by if you want and we can always test fit them before you buy. refunds are also available if the product is unused.
please tell me you still have me and a few buddies are looking for a few of these call me pls ASAP 647 994 5599
Yep I still make these.
I have a set in stock for the first buyer. Get your cars on the road or stiffen those frames for the track.
how much is shipping, I’m in cambridge
need both rails
