Here’s your fun winter project. Basic info, car is a rust free never seen winter 91 nissan sentra. I bought if from orlando in 08 and drove it home. It was suppose to be a winter car but i blew up the gti-r motor that was in it before even a single snow flake saw the ground. I put in a new gti-r sr20det very slowly and never got it running again. It currently does not get any fuel and I have tried everything I can think of and can’t get it to run. I don’t care, don’t want it anymore. I now have a miata as my daily and my rx7 as a project so this has just been sitting taking up room.
The Good:
Pulsar GTI-R sr20det, stock, down to the intercooler that doesn’t fit under the hood (hence why it isn’t on in the pictures).
Motor Mount inserts (I’m guessing energy suspension since they are red)
444 CC Injectors (I don’t know if they are the ones currently on the motor or the extra set you see in the pictures)
Custom 3 inch Exhaust Piping to Apex’I World Sport Muffler (Will need a downpipe fabbed up)
ACT 6 puck Clutch and Extreme Pressure Plate (rated @ 450 hp)
Fidanza 9lbs Flywheel (Drilled to fit Pulsar DET)
NX2000 Radiator w/ Dual Electric Fans
Custom Intercooler Piping (Not on the car but as seen in the pictures and will be included to make a front mount easier)
Walbaro Fuel Pump
Battery relocated to the trunk in a battery box with cut off switch and jumpers (but no battery in the car)
KYB AGX Struts (front) KB GR2s (rear)
Dropzone Springs
Suspension Technique Front Sway Bar
Front Strut Bar
Brand New Wheel Bearings
Brand New Brake Pads
New Control Arms
New Power Steering Rack including New Tie Rods
Autometer Boost Gauge
Autometer Air/Fuel Gauge
Dual Gauge Pod
Pulsar GTI-R Steering Wheel in good condition
Door panels already cut for component speakers
Tsuru Front Headlights and Corners
Tsuru Rear Taillights
Rocker panels are drilled for Sunny Side Skirts as the car previously had them
The Bad:
Car does not run. It cranks but does not get fuel.
Hood is dented from blowing off an intercooler pipe
Front bumper is Cracked
Sunroof leaks and does not open (gears in the sunroof are stripped)
Needs trim panels for both exterior and interior
No headrest
Extras:
Comes with spare ecu/wiring harness from when the old motor was in it
Comes with piping for front mount
Other spare parts as pictured. I want nothing to do with this car anymore so everything I have for it will go with it.
Feel free to ask any questions and I’ll do my best to answer them. The car hasn’t moved in a while and I haven’t even touched it in a while so this is all from memory.
Price: 1200
I feel this is fair, but i don’t know what these really go for anymore, but just a quick ebay search and the only gti-r motor I found was 1700. Feel free to make an offer, I’m not looking to part it out unless I have sell the drivetrain setup first.
