FS: 91 240 hatch w/ blacktop sr20det (needs some work)
This is just a feeler post, im not totally sure I want/need to sell just yet
I know its a bit of a novel, but it explains everything about the car, and my current situation, please give it a read.
Here’s my story. I bought an s13 hatchback last year that already had the sr20 swap done. The car was in much better condition than my previous 240, so that was a plus. The car ran amazing for the couple months I had it on the road until it was stored for the winter. Over the winter I had some issues with the oil filter housing gaskets which ended up causing more issues with the head. After buying random upgraded parts over the winter and the spring, it was time to pull the engine and have a better look at what was going on.
Fast forward to about a month ago. I pulled the engine, tracked down the oil leaking issue (housing gaskets as mentioned above), bought a shitload of new parts, took care of the minor rust issue i had on the inner wheel well, and a section of the driver’s side frame rail, then painted the engine bay gloss black. I ripped apart the engine, cleaned it up, decked the block and the head, ensured that everything was in proper order. Rebuild the head with a slew of new OEM parts (springs, retainers, gaskets etc) set the timing perfectly, and put it back together. Dropped the engine back into the car, then towed it back to my garage for further work.
Now, 2 weeks ago, I had the opprotunity to take a job in Edmonton for alot more money, so i jumped on it. I had 2 weeks give or take to finish up the car and at least have it all back together and/or in running status before I left or else it would never have gotten finished. Everything minus the piping for the exhaust was finished and ready to go, however, I simply ran out of time before leaving to go out west. So, the car now sits in Ontario at my fiance’s house waiting for me to trailor it back to Edmonton come October.
Now, trying to get my life in order and trying to start a family, as well as the prospect of a baby on the way, I have decided to try and sell the car. I need the money more to get things going out here than to have in a car that I never have time for anymore. So, here’s where the dealing comes in. I’m in Alberta till at least the first week of October, at that time i will be going back to Ontario to get my girl, and our shit, and head back west. Thinking things over, it would be 10x easier for me not to have to worry about getting the car trailor or shipped out here, and the hassle of getting the OOP done, this is why I somewhat have to get rid of it. I’ve put a ton of cash into this car, and I know i will never see it again, or break even at the very least, but please consider the quality of parts, and how some items are installed and absolutely brand new.
JUST TO CLARIFY, THE CAR IS IN ONTARIO. I WILL PAY HALF FOR THE SHIPPING FOR ANY SERIOUS BUYER
Here is a rundown of the car and what is needed:
  • front brakeline on driver’s side
  • 3’ cat by-pass pipe to install the new exhaust
  • New windshield
  • inner tie-rod on driver’s side
Now, here is why I am posting this now - I need the time to line things up so when I am back in Ontario, I will hopefully have something arranged with someone and ready for it to be sold. I should be back in Ontario for approx 1 week at the very most at the beginning of October, so if someone is interested either immediately or now until October, please dont hesitate to PM me or something, we can discuss things and work something out.
Here are the specs on the car
  • 50k on sr20 engine when purchased
  • Haven’t even driven the car since rebuilding the engine
  • rebuilt head with OEM parts (new gaskets etc)
  • Redtop Optima Battery
  • 160k on body
  • power windows
  • power locks
  • keyless entry
  • power mirrors
  • heat blows HOT
  • no A/C - taken out during swap
  • no rust on hatch
  • driver’s side frame rail fixed and reinforced (rusted areas cut out and replaced)
  • reinforced front end (where strut tower and frame rail meet)
  • no leaks anywhere
  • interior mostly gutted (have most parts if buyer wants them. I DO NOT have a passenger seat)
  • automatic seat belts removed
  • new OEM fatty o2 sensor with plug
  • stock 7 spoke rims grinded down and painted black
Engine & Drivetrain
  • 1996 SR20DET Black Top
  • Running at 10psi boost
  • Front mount intercooler 2.5" inlet and outlet
  • B&M Short Shift kit (installed, brand new)
  • Exedy Stage 1 clutch
  • Walbro performance fuel pump
  • Megan Racing 3’ turbo extension (installed, brand new)
  • Megan Racing 3’ downpipe (installed, brand new)
  • Megan Racing 3’ drift-spec catback (not installed, brand new)
  • 300zx fuel Filter
  • custom oil temp/oil pressure sending unit
  • Blitz BOV
  • Machined and lightweighted flywheel
  • Koyo aluminum rad (installed, brand new)
  • Samco rad hoses (installed, brand new)
  • Dual flex-a-lite electric fans (with thermo-switch) (not installed, brand new still in box)
  • Megan Racing light weight pully
  • Megan Racing Turbo exhaust manifold (installed, brand new)
  • Taka braided stainless steel turbo lines (oil & coolant) (installed, brand new)
  • Cometic 1.2mm metal head gasket (installed, brand new)
  • Nismo slave cylinder (installed, brand new)
  • OEM Nissan throwout bearing (installed, brand new)
  • 10w30 Royal Purple oil
  • 80w90 Royal Purple transmission oil
  • Nissan oil filter
Suspension & Brakes:
  • Megan Racing 32-way adjustable coilovers
  • Brembo Cross Drilled front and rear rotors
  • New sway bar links
  • Upper front and rear strut tower braces
  • JDM Kouki Wing
Interior
  • Nardi wheel
  • HKB hub
  • Bride Brix driver’s seat
  • Bride seat bracket
  • Sparco Road shift knob
  • Nismo Racing floor mats
  • Megan Racing A/F gauge
  • Megan Racing boost gauge
  • Megan Racing volt gauge
  • Megan Racing oil pressure gauge
  • Megan Racing oil temp gauge
  • Battery located to hatch
  • Blitz turbo timer: DC model
  • Kenwood CD head unit
The list looks a little short, I’ll add more once i think of it. As you can see, there is quite the list of upgrades and parts available on this car. Most of which are brand new from within 1 month ago, and things like the coilovers and brakes are brand new from last September, and keep in mind the car was stored in November and hasn’t been back on the road since.
Here are a ton of pictures that outline various parts of the car, as well as doing the upgrades. I have more, I just gotta find them
http://www.cardomain.com/ride/2105933/
As for as price, im asking 8,000$obo. I am flexable on the price, to a point. No lowballers please. And no, I will not, part the car out.
Please PM me or add me on MSN to chat - saultmusic@Hotmail.com
So really what needs to be all worked on to make this car fully functional? It seems like you’ve put a lot of effort and money into this car. It’s going to be hard to sell a vehicle to Albertans in Ontario. If the car was here, I’d take a serious look at it for sure. It looks wonderul inside and looks like things have been taken care of well. Good luck with the sale!
to be out and driving the car safely? the brake line, and the by-pass pipe so the exhaust can be installed. You will need to get the windshield replaced (apple autoglass quoted me 276$ installed for a new one).
just a question, but were you on that driftnation site at all?
No, I don’t believe I have, why?
No, I don’t believe I have, why?[/quote]
Thought i remember your car on there. Must be one that looked like it.
I have a question with the seat belts. You say that you removed the auto seat belts. Is this car from the states?
Looks like a nice car, GL with the sale.
maybe try posting on www.son240sx.ca for an Ontario buyer.
I have a question with the seat belts. You say that you removed the auto seat belts. Is this car from the states?[/quote]
yes, i beleive it is one of the USDM models of the 240.
You could also post here. I believe it is for people in toronto and ottawa
http://forums.neo240sx.ca/index.php
thanks dude, i havent got around to posting it on neo yet, but it is on son240, ive been a member on there for ages now, as well as posted here.
Update on the car…
The way it looks right now, I will not be going back to Ontario in October.
Price Drop to 7500$obo to take everything. I will also arrange shipment for buyer, and will even pay half!
Cost of items needed:
  • bypass pipe for exhaust - 100$ (pdm-racing.com)
  • new windshield - 276$ installed (apple autoglass quote)
  • Inner tie rod (not needed just yet) - around 100$
Now, with the price drop, as well as I’m offering to pay half of the shipping, how can you go wrong with this deal? I know it needs a bit of work, and some TLC, I’d like to see someone who can appreciate the car and the parts that are on it, and to go to a good home. Please PM me or add me on MSN to work something out.
so this car being a 1991 240 from the states, is it even able to be driven up here?
Correct me if im wrong, but I thought those cars weret legal because of the seat belts. Because you removed the auto seatbelts, is it now able to be insured and registered in canada?
they were always legal as far as I know. I purchased the car from some guy in Toronto, he had it plated and insured, and I also had no problems passing safety and getting it insured. You do not have to worry about it not being insurable, you will be able to drive it 100%
anything that is here and insured and registered is HERE and cant be said otherwise now , as long as it doesnt have power seatbelts then I am game …
dont sell her Scott
