FS: 91 240 hatch w/ blacktop sr20det (needs some work)
This is just a feeler post, im not totally sure I want/need to sell just yet
I know its a bit of a novel, but it explains everything about the car, and my current situation, please give it a read.
Here’s my story. I bought an s13 hatchback last year that already had the sr20 swap done. The car was in much better condition than my previous 240, so that was a plus. The car ran amazing for the couple months I had it on the road until it was stored for the winter. Over the winter I had some issues with the oil filter housing gaskets which ended up causing more issues with the head. After buying random upgraded parts over the winter and the spring, it was time to pull the engine and have a better look at what was going on.
Fast forward to about a month ago. I pulled the engine, tracked down the oil leaking issue (housing gaskets as mentioned above), bought a shitload of new parts, took care of the minor rust issue i had on the inner wheel well, and a section of the driver’s side frame rail, then painted the engine bay gloss black. I ripped apart the engine, cleaned it up, decked the block and the head, ensured that everything was in proper order. Rebuild the head with a slew of new OEM parts (springs, retainers, gaskets etc) set the timing perfectly, and put it back together. Dropped the engine back into the car, then towed it back to my garage for further work.
Now, 2 weeks ago, I had the opprotunity to take a job in Edmonton for alot more money, so i jumped on it. I had 2 weeks give or take to finish up the car and at least have it all back together and/or in running status before I left or else it would never have gotten finished. Everything minus the piping for the exhaust was finished and ready to go, however, I simply ran out of time before leaving to go out west. So, the car now sits in Ontario at my fiance’s house waiting for me to trailor it back to Edmonton come October.
Now, trying to get my life in order and trying to start a family, as well as the prospect of a baby on the way, I have decided to try and sell the car. I need the money more to get things going out here than to have in a car that I never have time for anymore. So, here’s where the dealing comes in. I’m in Alberta till at least the first week of October, at that time i will be going back to Ontario to get my girl, and our shit, and head back west. Thinking things over, it would be 10x easier for me not to have to worry about getting the car trailor or shipped out here, and the hassle of getting the OOP done, this is why I somewhat have to get rid of it. I’ve put a ton of cash into this car, and I know i will never see it again, or break even at the very least, but please consider the quality of parts, and how some items are installed and absolutely brand new.
Here is a rundown of the car and what is needed:
  • front brakeline on driver’s side
  • 3’ cat by-pass pipe to install the new exhaust
  • New windshield
  • inner tie-rod on driver’s side
    -> both items I could take care for the buyer when i go back to ontario
Now, here is why I am posting this now - I need the time to line things up so when I am back in Ontario, I will hopefully have something arranged with someone and ready for it to be sold. I should be back in Ontario for approx 1 week at the very most at the beginning of October, so if someone is interested either immediately or now until October, please dont hesitate to PM me or something, we can discuss things and work something out.
Here are the specs on the car
  • 50k on sr20 engine when purchased
  • Haven’t even driven the car since rebuilding the engine
  • rebuilt head with OEM parts (new gaskets etc)
  • Redtop Optima Battery
  • 160k on body
  • power windows
  • power locks
  • keyless entry
  • power mirrors
  • heat blows HOT
  • no A/C - taken out during swap
  • no rust on hatch
  • driver’s side frame rail fixed and reinforced (rusted areas cut out and replaced)
  • reinforced front end (where strut tower and frame rail meet)
  • no leaks anywhere
  • interior mostly gutted (have most parts if buyer wants them. I DO NOT have a passenger seat)
  • automatic seat belts removed
  • new OEM fatty o2 sensor with plug
  • stock 7 spoke rims grinded down and painted black
Engine & Drivetrain
  • 1996 SR20DET Black Top
  • Running at 10psi boost
  • Front mount intercooler 2.5" inlet and outlet
  • B&M Short Shift kit (installed, brand new)
  • Exedy Stage 1 clutch
  • Walbro performance fuel pump
  • Megan Racing 3’ turbo extension (installed, brand new)
  • Megan Racing 3’ downpipe (installed, brand new)
  • Megan Racing 3’ drift-spec catback (not installed, brand new)
  • 300zx fuel Filter
  • custom oil temp/oil pressure sending unit
  • Blitz BOV
  • Machined and lightweighted flywheel
  • Koyo aluminum rad (installed, brand new)
  • Samco rad hoses (installed, brand new)
  • Dual flex-a-lite electric fans (with thermo-switch) (not installed, brand new still in box)
  • Megan Racing light weight pully
  • Megan Racing Turbo exhaust manifold (installed, brand new)
  • Taka braided stainless steel turbo lines (oil & coolant) (installed, brand new)
  • Cometic 1.2mm metal head gasket (installed, brand new)
  • Nismo slave cylinder (installed, brand new)
  • OEM Nissan throwout bearing (installed, brand new)
  • 10w30 Royal Purple oil
  • 80w90 Royal Purple transmission oil
  • Nissan oil filter
Suspension & Brakes:
  • Megan Racing 32-way adjustable coilovers
  • Brembo Cross Drilled front and rear rotors
  • New sway bar links
  • Upper front and rear strut tower braces
  • JDM Kouki Wing
Interior
  • Nardi wheel
  • HKB hub
  • Bride Brix driver’s seat
  • Bride seat bracket
  • Sparco Road shift knob
  • Nismo Racing floor mats
  • Megan Racing A/F gauge
  • Megan Racing boost gauge
  • Megan Racing volt gauge
  • Megan Racing oil pressure gauge
  • Megan Racing oil temp gauge
  • Battery located to hatch
  • Blitz turbo timer: DC model
  • Kenwood CD head unit
The list looks a little short, I’ll add more once i think of it. As you can see, there is quite the list of upgrades and parts available on this car. Most of which are brand new from within 1 month ago, and things like the coilovers and brakes are brand new from last September, and keep in mind the car was stored in November and hasn’t been back on the road since.
Here are a ton of pictures that outline various parts of the car, as well as doing the upgrades. I have more, I just gotta find them
http://www.cardomain.com/ride/2105933/
As for as price, im asking 8,000$obo. I am flexable on the price, to a point. No lowballers please. And no, I will not, part the car out.
Please PM me or add me on MSN to chat - saultmusic@Hotmail.com
what do you mean automatic seat belts removed? do you still have the a/c component?
US 240’s came with auto seatbelts. As soon as you open the door, they move on a slider to let you out of the car, or holds you in when you close the door.
all the A/C shit was thrown away.
i already have 240 but i really like yours someone should for sure jump on this i know ide be all over it if difdent have one already :shock:
thats an awesome price- even myself, with great low prices, couldnt build one with those mods for that price !
thanks Varun, I’m still on the fence as to what to do, one minute I want to sell it and get my family stuff together, but the next minute I remember how much fun this car is, and want to keep it. At the very least this is a feeler post, so if the right person comes forward we might have to arrange a deal of some-sort.
bump. Someone please come forward.
Update…
The way it looks right now, I will not be going back to Ontario in October.
Price Drop to 7500$obo to take everything. I will also arrange shipment for buyer, and will even pay half!
Cost of items needed:
  • bypass pipe for exhaust - 100$ (pdm-racing.com)
  • new windshield - 276$ installed (apple autoglass quote)
  • Inner tie rod (not needed just yet) - around 100$
Now, with the price drop, as well as I’m offering to pay half of the shipping, how can you go wrong with this deal? Please PM me or add me on MSN to work something out.
hey, where in ontario?GTA?
The car is currently in Sault Ste. Marie. I would arrange shipping to the GTA, it would be able 500$ or so, and i would go splits with the buyer.
I’m IN SSM… I’d be interested in at least taking a look at it, the price might be a touch high for what I’m looking for, but I could at least vouch for it.
…PM’d
bump.
Car is still for sale.
I’m still looking to buy it Scotty, I have another appointment (finally) with my bank next Thursday. Hopefully I’ll be set with the money then.
…Please don’t sell it from under me…
BUMP, still for sale, need money BAD. Make a reasonable offer and i just might bite. No lowballs please.
BUMP
7,000$ obo, i need this car gone.
Money should be here by Wednesday.
