FS 92 hatchback -rolling chassis
FS 92 hatchback -rolling chassis -with all 5 speed components and a KADE for parts only ( missing cams starter ,alt etc. and has a spun bearing)
The good:
------good strut towers -upper frame rails and a decent body
------dark tinting all around 15%
------ABS module removed -non ABS huds installed and lines rerouted
------rear and marker lights tinted
------replace hatch is rust free (no wing)
------VLSD and HICAS sway bar – hicas lines removed
------front end 95% rust free including lower and upper rad supports
The reality:
------This car needs work- not a one weekend fixer upper
------needs an engine -tie rods and other parts
------comes with a box full of parts (fan,rad shroud etc)
------decent start for a track or project car
------needs work-read-needs work
------currently setup as a 2 seater due to Sparco bar/harness
This car is for sale with the Sparco seats (2) , rails, harness and bar for $1100. or $800. not including the Sparco parts.
I will be posting another FS thread with a number of aftermarket parts that will have a lower price if bought at the same time as the car.
PM your name and contact phone # if interested.
Thanks John
Bump -spring is coming !!
so… what needs work?
pics of the body?
if u decide to part out, i need passenger side fender, both flip ups, center console, carpet and shift boot.
I’ve seen this car and it is actually in great shape. If I were into hatchbacks (or if it were a coupe), this thread would be finished!
Know someone interested in this John. Ill call you sometime to see when is best to come look at it.
Bump
hey john, i like the seats, are they for sale seperatly? i can give u crappy stockers to put in there but im sure u have tons.
i neeed a set of s13 doors! pm me pleeeeeaaasseeeeeee
i might have someone interetsed without the seats …is there any holes anywhere? floors or hatch or anything?
The hatch is in good shape -no wing -no rust. Strut towers are in good shape -very little rust. the frame rails are decent --. The rear wheel wells need some work but there are no holes in the exterior of this car.
The only reason for posting that it needs work is to avoid an inexperienced person buying this on a Friday night thinking it will be finished by noon Sat. The car is in decent shape but needs an engine and other finishing work .ie (seats if buying it without -a redo of brakes /suspension /fuel system depending on your intended use.)
Hi John, just out of curiosity, what parts would the buyer have to purchase to get this thing running? Does it come with all of the brakes and shocks and stuff?
Would he just have to buy fluids and some hoses and stuff? Sounds like it’s just some assembly, drop an engine in and you’d be pretty close to road worthiness?
Missed your post Theo --so here is more info.
This car needs an engine --most of the engine bay stuff is there -just missing the AIV assembly that sits on the driver's side strut tower. The car has a complete brake and suspension OEM and well used will need to be looked at/replace some parts ie tie rods ,brake pads . This why the car is a good start as a project car if you are replacing all that stuff anyway or as a daily driver which will require some replacement stuff. The right person with an engine available and a good working knowledge of S13's could probably get this roadworthy in a weekend but as my previous posts if you do not have some experience and a good understanding of these cars this may be to much for you. ( I do not want to give the idea that anybody could have this car on the road in one weekend)
Any questions - just pm me
Thanks John
whats your lowest offer on the car with out the sparco stuff or will you trade
for a 99 kawasaki kx 80 2 stroke dirtbike?
hey john. is the chassis still around. what will you take without the sparco stuff?
Thanks Jesse.
As of now the seats are no longer available and I may part the car out if it doesn’t sell in the next couple of months.
PM works best for me.
John
John ive been emailing you about those drivers side pics…
We lost most of them when our computer crashed but I just found one of the driver’s side and emailed it to you.
John
Bump
