FS: Autometer Phantom 2-1/16" Oil pres. gauge $50 *pics
Comes complete with:
  • 2-1/16" gauge
  • Nylon tubing
  • NPT fitting (top 3 pieces shown in first pic below)
  • Installation article: http://240sx.cubicdesign.com/article4.php
  • Free installation of gauge provided by me (only on weekends) :naughty:
PRICE: $50CAD (firm - no more no less)
You can purchase an Autometer fitting (Part #2269) that will let you tap
directly into the stock oil pressure switch location. You can buy this
part from most specialty auto shops for ~$20CAD
Here’s the fitting on Summit’s website:
http://store.summitracing.com/default.asp?target=partdetail.asp&part=ATM-2269&N=120+4294925228+4294923437+302495
Or you can go to http://www.adaptall.com and buy the 3 pieces mentioned
in my article above. These three pieces cost less then $15CAD and will
let you run your stock oil pressure switch as well.
AdaptAll is located: 1 Daybar Avenue, Rexdale, Ontario, Canada M9W 3N8
SPECIAL
I will also install the gauge for you provided you come with the
adapters/fittings (mentioned above) in hand. Removal of the stock oil
pressure switch requires a 27mm deep socket which I have.
The fittings you will need to run a tee with stock oil pressure switch.
http://240sx.cubicdesign.com/images/article4/pic2.jpg
The gauge (only oil pressure gauge)
http://240sx.cubicdesign.com/images/article4/pic4.jpg
how long does the install take, and where did you run the oil line through the firewall?
The install takes no time. I don’t mind getting dirty. :naughty:
Just that not everyone has a 27mm boxed end wrench or deep socket (I
ended up buying one just for this) so I figure might as well install it on
your car while you are here.
I strongly suggest anyone buhing this to get the fittings from AdaptAll.
Not only is it cheaper then the Autometer adapter but it will let you run
the stock oil pressure indicator on your gauge cluster.
I drilled a hole to run my battery cable but I originally had it going
through the rubber vent grommet (for A/C - I had no A/C).
hmmm wanna give it a shot on a rb20?
i’m lazy
Sure. I believe all Nissans share the same thread size; 1/8 BSPT.
You’re more then welcome to come by on the weekend. PM me for
address/phone #.
dude have to pass. bought a wicked entertianment centre for my tv.
400watts, woot!
Someone buy this thing.
Shit! Im throwing in a free install.
TTT
Free install :run: :run: :run: :run: :run: :run: :run: :run:
BUMP
I’ll buy if you install it on my 200sx
Provided you bring either of the fittings I mentioned in my post…
I’m only good for this anytim weekends, or after 7pm Weekdays…
PM me for details
BUMP
Ed, you still want to do this? Don’t leave me hangin…
:run: bump :run:
I’ll take it, pm
