When installing an Autometer oil pressure gauge (or any other non-metric gauge),
you need a conversion fitting to adapt to the metric system used by the 240sx.
Autometer recommends you buy one of their NPT to BSPT fittings which
costs somewhere around $20 or $30.  However you can go to AdaptAll
in Toronto (http://www.adaptall.com/) and get your fittings from there.
If you plan to keep your stock oil pressure indicator light (on your dash)
here’s what you need to buy:
1 - 3-way 1/8" Female BSPT fitting
1 - 1/8" Male to 1/8" Male BSPT fitting
1 - 1/8" Male BSPT to 1/8" Female NPT fitting
Total cost for these fittings is about $10.
Tools/parts needed:
- 22mm deep socket
 - Ratchet
 - Approriate sized wrenches/ratchets to tighten the various fittings
 - Teflon tape
 - Autometer gauge, fittings and nylon tubing.
The stock oil pressure switch is located near the oil filter.  It’s a very tight
fit so the best thing is to unbolt it from under the car.  The size of the switch
is 22mm, so you will need a 22mm deep socket to remove it.
For my setup, I ended up putting the Autometer adapter in the middle of the T-fitting
and the stock switch on the other end (see pics).
Be sure to put some teflon tape on the threads before you tighten the
fittings.  I had no teflon tape so I ended up using RTV sealent.  :oops:
Stock oil pressure switch
The fittings
Fittings installed (minus the nylon oil pressure tube)
Gauge (the switch if for my electric fan)
Once everything is installed, check the fittings and connections for leaks.
Let the car idle, take it for a spin and monitor the reading.  If you lost
some oil while taking the oil pressure switch out, be sure to top it off.
If it’s any easier, take the oil filter out when doing this install.
On idle, on average, you will see about 20psi.  Higher up in the
RPM/speed/gear, your average PSI will be between 60psi and 70psi.
Good luck.
