long shot but I heard there may be a person on here interested in this kit.
reason for sale: came with a engine I purchased and have no use for it.
all parts have a couple hours of actual run time
renegade hybrids 944 lsx swap kit
basic swap kit list: retail $2100
[TABLE=“width: 100%”]
Renegade custom adapter-bellhousing complete and pre assembled with hydraulic throw out bearing, custom hydraulic hose and fittings, and mounting hardware.
Custom 12 inch LS Series clutch disc with Porsche center spline.
Renegade motor mount kit complete with uprights, billet block plates, rubber isolators, and hardware.
Renegade custom LS Series road-race oil pan with windage tray and spring-loaded trap doors for proper oil delivery.
LS Series remote oil filter mount.
Renegade cross member and sway bar drop kit.
Custom 944 to LS Series pilot bearing.
Renegade brake master cylinder mount and pushrod.
Custom ignition coil mount bracket
[/TABLE]
Extras/add ons: $2500 ish
</b><b>RENEGADE CUSTOM BUILT LS Series HIGH FLOW HEADERS:</b> With 1¾-inch primaries and 3-inch collectors.
<b>CERAMIC HEADER COATING:</b> High temperature polished coating inside and out.
<b>COOLANT TEMPERATURE SENDING UNIT:</b> To work with your stock factory gauge and install in your LS V8.
<b>OIL PRESSURE SENDING UNIT:</b> To work with your stock factory gauge and install in your LS V8
<b>KEVLAR HIGH PERFORMANCE CLUTCH DISC UPGRADE:</b> Must be ordered with our Stage Two pressure plate.
<b>STOCK 12" GENUINE GM FLYWHEEL </b>
<b>HIGH PERFORMANCE STAGE-TWO YELLOW PRESSURE PLATE</b>
<b>ENERGY SUSPENSION MOTOR MOUNT UPGRADE</b>
Intake with K&N carbon filter
some other random small stuff
pm me for info on getting pics of all the stuff
if anyone helps sell this set up ill hand them some cash/paypal
thanks
price again is 2500 or B/O
