Fuel Filter
I’ve never done one of these in a pressurized system before. My Haynes manual says I have to take off my gas cap and take my fucking dashboard apart to flip a switch behind the stereo. The guys at McCandless Auto Parts said I should forget the switch and hold a rag over the fuel. Thoughts?
un pop gas cap… n just take it of let the fuel drip n clean it up install filter. then b4 u start your car again prime the fuel pump by turning the key just b4 u crank it. then off then turn the key almost till u start it again then turn n drive away. then check for leaks
btw u should hear the fuel pump go vrrrr. then u know its ready to go ! good luck
thanks. now i have something to do tomorrow.
the best part is that mike actually kinda sounds like he knows what he is talking about. and there should(but doesnt have to be) a bleeder screw on your fuel rail. i know that my lt-1 has a bleeder screw that you push down adn it releases presure.
either way WATCH you eyes. it will squirt out and get in your eyes. and dont worry about that switch.
since when do u push a screw!!!only in sex do u push to screw!!!:tounge:
well on the lt-1’s dont you just use your finger nail to push the bleeder screw?? and then if you really wanted to remove it cant you unscrew it all the way?
its a shrader vavle!!!:tounge:
aww thats wrong !! delete my post n steal my correct spelling answer !!! :reloading
yea yea yea. what eva
:smiley: :wink: :tounge:
if you cant get it let know i could lend a hand-
