so do you guys run straight an or do you drop the extra $5 for the steel ones?
fucking blowin’ money like it’s my job…
I’m ex aircraft mechanic and i say an all the way.
too bad you aren’t an english teacher and actually read what i asked.
do you guys run the standard AN fittings or do you spend the extra cash on the STEEL AN FITTINGS
:asshole
Usually straight AN unless can’t find the right ones then I use steel.
sounds good! thnx guys
run an
if you need a AN wrench i have an adjustable one one that works on all size you can use
