gas lines
i need to put gas lines on my s13 that im currently building
is there a certain size of gas line that i have to use? its all stock including fuel pump
and where would i get gas lines napa? canadian tire had none
i just need a straight gas line to go from firewall back, then im running rubber hoses
any help would be great
Napa sell’s fuel line as long as 1’ to 6’ in straight line’s, go to the one in milton, and tell them spike from oakville napa sent you, they mite give you a deal, because we are co owners of that one in milton.
Fuel lines are 5/16"
toronto240sx can get you the 3 oem lines for $114 ish tax in.
Find a place that will do plastic lines for you. I know a shop in Streetsville, its a bit overpriced but they will never let out on you, cant rust and full warrenty on parts and labour. Another option is powdercoated lines which will outlast cheap lines but again its a bit more expensive. Depends what you want out of the car and how long your going to keep it. I know sum1 who just used rubber lines for the sending line and return all under the car and hasnt had a problem. Get some nyce stainless tubing and route the rubber lines threw that for looks and a bit of protection against the elements under the car!! Hmm two of those lines under the car would look pure badass. Something i may have to do… :idea:
ok thanks guys…im gonna go check out the prices tonite
Plastic lines, compression fittings and lots of zip ties. It’s not real plastic, it’s a nylon polymer.
They will stretch so use a lot of zipties…
