110 miles used half a tank… guess im running real real rich cause the exhasut smells like its straight from the gas pump. guess its time plugs wires :hs: and then check timing
cause i dont know how to fix that shit.
:scared:
:scared:
plugs and wires are not gonna stop you from running rich… :slap:
you need to soak a rag in diesel fuel, stuff it in your gas filler neck, and then light it on fire. That will fix your rich condition in no time…
02’s???check engine light on?
engine light on???
if not i can plug it into the scan tool and tell you how rich you actually are running and if you have any pendind/possible codes…
your timing isnt adjustable unless you buy the steeda setup
no check engine light… running a little lopey and surges from time to time.
well that sucks
not sure how your car works but try unplugging the O2 sensor in your downpipe… see if the problem stays the same.
dont’ new mustangs have like 4 o2 sensors?
holy jesus… disregard my post then. i know nothing about the mustang
i think 2 pre cat and 2 post cat, the only ones that would matter would be the pre cat ones
He dosen,t have a newer one though,what is it jeremy?a 98?
adjust your distributor it may be a cunt hair off
or
when i say new mustang i mean anything after 95
you mean after 96 :finger:
ford owner > half breed owner ![]()
) only run 93… did find out my parents ran 87 one tank when they borrowed it :mad:man thats straight cold hearted.
you could have a stuck injector. Oh and yes, all 4.6’s have 4 O2 sensors as blue meanie said
