Well my sister has decided to go and loose the key and remote to my grandmas 06 Malibu…I’m being blamed for it any information on replacing the fab thing and key…i see that they have them on eBay for about 10 dollars can someone help with the programing?
Remove the ignition key from the ignition lock cylinder
Close all the doors
Press and hold unlock on the door lock switch (on the door)
While holding the door lock switch in the unlock position, insert and remove the ignition key twice. DO NOT ROTATE THE KEY… JUST SLIDE IT IN AND BACK OUT.
Insert the ignition key the third time, leaving the key in the ignition cylinder. DO NOT TURN KEY
Release the door lock switch. You will hear 3 chimes indicating the transmitter
programming is active.
Press and hold the lock and unlock buttons on the keyless entry remote at the same time (one remote) for 12 seconds. You will hear two chimes. This indicates the
transmitter has been programmed.
Repeat step 8 for all additional transmitters to be programmed
Exit programming by removing the key from the ignition cylinder
This worked on my 97, dunno if its different for newer sorry.
The newer 00+ models mostly need to use the TechII to get them to work. Some of the lower end, or models who did not change body styles until after may still be able to.
FYI, I have a bunch of used remotes here for GMs. If you have the numbers off the back of an original, or off the Keyless receiver, I can check what I have and let you know if I find a match.
