I can’t get the hotpipe to line up with the ic piping… i’m stumped… they are on a 90 degree from each other. If someone knows the answer please post asap, i’ll be in the garage trying to figure it out.
what do you mean you cant get it to line up? Looks fine in the picture. You need a 90 degree bend there, a coupler will do the trick.
or
If its too far forward, push it further in on the opposite side or cut the opening where you stuffed the IC piping in bigger and move it around until you have everything lined up.
first thing that came to mind was a 90 degree coupler… I just wanted to double check
i can get you a 90 deg. coupler at PI, come see me.
they arent cheap tho
