When I start my car, it runs really lean and shitty. Like it will barely hold idle. This is only until I rev the motor. At this point, all the lights on the dash go brighter and the car starts idling fine. Also, when the car first starts, the battery voltage is steady at 11.8. After I rev the car and the dash lights are bright, the voltage is a steady 13.8. Anyone know what is wrong?
Something might be shorting out your battery my HID’s did that too me… I’am pretty sure reving would’nt make your voltage rise if you had a ground problem…
Got the battery tested and it’s fine. Also the belts are d
fine.
We did a little bit more testing. When I first start the car and it’s running shitty, the voltage is dropping slowly and the timing is jumping around like crazy. This even happens when another car is boosting mine.
The timing and voltage is fine when the engine is revved once. We even tried grounding the battery and engine block with more wires.
