^^ not trying to answer your question with this . . .just to let you know
i found this on sun auto’s web page. The reason I keep bringing these guys up is because i’ve seen tons of dynos with their product and on each one, it works . . .
How much horsepower/torque will I gain with Hyper Ground System?
As with any product, the amount of benefit gained will vary between applications. Some applications we have tested have gained 16+ horsepower, but the average gain seems to be between 3-6 horsepower. Hyper Ground System is not a product that is used to boost your vehicles power; it is designed to increase efficiency in the electrical system to help your vehicle operate at its full potential. A good comparison would be to examine the effect of changing the intake and/or exhaust system of your vehicle. By allowing the car to gbreatheh easier by installing a higher flowing exhaust and/or intake system, horsepower which is otherwise lost to system inefficiencies is restored. Similarly, Hyper Ground System affects your electrical system in the same manner. So, how inefficiently your factory electrical system is operating in its current condition will determine how much power can be restored by installing Hyper Ground System. One thing to consider is that virtually 100% of our customers are completely satisfied with their Hyper Ground System purchase, and simply amazed that such a simple addition could help their vehicle perform so much better.
Hyper Ground System is just a bunch of wires; I can make my own set with speaker wire for a fraction of the cost so why should I spend over $100 for yours? Why should I buy Hyper Ground System when other companies sell something similar for a fraction of the cost?
Sun Automobile develops, markets, and manufactures its products to provide the highest quality, reliability, and performance value available. Hyper Ground System was designed from scratch by our engineers and has been tested and proven to be highly effective. The cables used in Hyper Ground System are unique; in fact, the cables are made to our proprietary design that our engineers have developed to provide the lowest resistance electrical connection while minimizing electrical interference. Our 99.99% pure copper, 1477 strand, multi-layered shielding design is unlike anything else available. Unlike off-the-shelf wire, Hyper Ground System was designed specifically for its use. As a provider of OEM parts to Mitsubishi, Subaru, Toyota, Nissan, etc. it is required for us to meet or exceed their standards for durability, temperature resistance, corrosion resistance, etc. For you, this means you are getting a product which is much better quality, durability and performance than something you can piece together on your own or purchase from our competitors. Sun Automobile was the first company to research, develop, and successfully market grounding systems to consumers, so choosing to purchase Hyper Ground System identifies you as an educated person who understands the importance of thoroughly researched, superior quality and performance products.
Hyper Ground System comes complete with the hardware and instruction manual. If you choose to install the product yourself, all you need are basic hand tools and a little time to complete installation. Our competitorsf product, which often does not include instructions, does not offer technical support, is often constructed with inferior materials, and is not necessarily proven to be effective. Constructing your own kit, which requires you to source (inferior) materials, involves labor and time for assembly, without any guarantee of effectiveness or even risk of damaging components in your vehicle, does not necessarily guarantee a proper installation or effectiveness to increase electrical efficiency. Furthermore, adding the cost of your time and labor on top of the cost of materials would probably amount to more than the cost of our kits, and would not include our technical support should any issues arise.
