So last drift day, I had a short in my wiring somewhere and kept blowing fuel pump fuses. After some help from the drift posse crew (Peter and Francisco), I managed to directly wire the pump to the battery so I could keep on drifting.
Now, I want to do it properly. So I’ve done some research and have one small problem.
So you run power directly from battery, to fuse, to relay, then to pump. And run the fuel pump switch using the grounds, with a ground being directly to the body near the fuel pump.
My question is how do I wire the actual relay into the system. I opened up both the EGI pump and EGI relay (also don’t know which of the two is for the fuel pump), and there is 4 wires to each. EGI has 3 reds 1 black, and EGIi pump has 4 blacks with stripe on each. Which of the two relays do I use? Which of the 4 wires do I wire up for the relay to work correctly with my system?
it literally relays, or joins, two circuits together
it lets you control high amperage circuits (ie fuel pump) with a low amperage switch
you will still need a switch to “turn on” the relay, though
in the oem setup it is the ecu that “turns on” the oem fuel pump relay, thereby controlling the fuel pump operation (for example, the 5-second priming sequence)
if you wanted to forget about the ecu and just want the fuel pump controlled by its own on/off switch, it’s very easy to wire (but yes you will still need a relay)
That’s what I did cept I used the ecu signal wire directly from ecu to control relay instead of battery. And then I put the switch somewhere for theft purposes
So you should have a heavy gauge power wire running to the relay, from the relay to your pump, and you should have a smaller circuit (the oem fuel pump circuit) controlling the relay, with an additional switch wired in for anti-theft. You shouldn’t have any problems with that. It’s a common solution for those running Walbros or other higher output pumps than stock. As long as everything is wired like Mike drew out (nice drawing btw buddy), you should be good to go.
