When I first got my S14, the fan only worked on setting “4”. One night it stopped working at all. THe next morning it worked for about 5 minutes again, then stopped. Now I’ve got nuthin. Since it worked perfectly in setting 4 before, I’m wondering if its possible that its just the switch.
Otherwise, does anyone know if the S13 blower motor will work for me? (Still have it in my parts car).
Thanks!
Jeff
also check your resistor pack. It has a different sized resistor for each fan speed, they sometimes burn out. Ussually they are located in an easy to access place, but not always!
If that solution doesn’t fix the problem its more likely the resister behind the glove box. take the glove box off and its right there 2 screws and its out. I’m pretty sure your S13 parts car resistor will work for that as well!!
Well I found the resister no problem on my S13, but can’t find anything similar on the S14. Anybody know where it is?
