Hi I just got an s14 but the fan for the heat inside the car wount go on. Even on 4 still nothing. Does anyone know how I can make the fan work for the heat? I’m freezing need some help ASAP. Thanks
Swap in a new blower motor. That’s most likely the problem.
Check your blower motor grounds and make sure the power is properly connected. With age sometimes the connections get dirty and lose connectivity
yup! grounds could be it
replacing a blower motor is a bitch
blower motors are kinda common on S14’s. If you find you need a new one, call napa, IIRC they weren’t too expensive.
