i’m getting heat but only a tiny bit i’ve checked the fuses there all fine cleared the snow off the front and still no heat any possible reason help me out here
im having the same problem as you
i dont know if its a common problem but the lower i put the heat the hotter it is… but if i trow it on full blast it feels cold… it brings warm air in at lower settings but not hot enough compared to other cars… any thoughts about it?
Just block the flow of coolent and when you motor heats up there will be lots of heat comming form your heater
everyone but benson check and probably replace your Thermostat
