HELP - HOW TO CHANGE LOWBEAM HEADLIGHT ON 97 KOUKI?
yeahhhh, i’m planning to change my lowbeam to hids and i’m wondering how to change my headlight?
do i have to take out the bumpeR or i can do that without.
thanks
SAMMM
duuuuuddeeee…GOOGLE IS YOUR BEST FRIEND…
Id offer to do it right the first time for you for $75. Id do a real clean install mounting the ballasts and routing wiring.
You’ve got to be careful when installing the bulb and need to modify the metal retaining clip to hold the HID bulb in place as well as drill a large hole in the dust/water cover and install the supplied rubber grommet that your kit should have. Im just saying its not plug and play.
