HELP! Need lifter part! please read
On the top lifter there is the clip that is a piece of wire size of twist tie wire that holds all the guts of the lifter in. One of my one lifter the clip worked its way out and the clip got beat up by the pushrod. Does anyone have an old Ford lifter (I don’t know if GM/ls1 lifters have the same size clip) that I can use the clip from? the lifter and pushrod are fine and I don’t want to buy a whole lifter just for the clip.
Once again I need the horseshoe shaped wire clip that fits on the top of a ford windsor lifter asap.
Thanks
