not bad ,but do i need this to do it to run ls vtec?..the kid allready gave me the b16 vtec ditsy, the soleniod …and a few other things…sorry guys im new to the honda game and dont much more than the head will fit on any b series block…
The kit will give you the other parts you need to make it work. You need the dowel pins to fit the head to the block, the reworked head gasket, and the oil supply line for vtec.
You can get the parts seperately and save a few bucks, but just get the kit - you won’t regret it.
thanks alot for all the info sureshot…youve been a big help…hopefuly i get this shit goin soon …ill throw pics n what not up when i do…oo btw do i need anything else like wiring harnesses, ecu’s or anything?
your gonna need a vtec ecu, and wire in the pressure switch and soleniod
would i be able to use the ecu from the b16 it was pulled from?
as long as its obd 1.
is your car obd1?
http://b20vtec.com/forums/showthread.php?t=56400
http://www.sportcompactcarweb.com/tech/0411scc_ls_vtech_engine/
Start with those…
BTW - you will need to chip the ecu to get it to run right, so make sure it’s OBDI. Get a conversion harness if it’s not.
yes its obd1 and its chipped…nah that aint mine the one im gettin is teal…thats this eric lus kid i think…
lol
