help sound when startup
hey a few days ago my car started to have this sound when i start it up its like a 2 second sound
hey i was wondering if anyone knows what this could be
just uploaded this
Sounds like your starter is about to die, or your flywheel is missing some teeth. Or something wrong with the bendix. It sounds like it only happens when your cranking? Hard to tell without the car in front of me.
most deffinatly sounds like the starters bearings are toast or teeth on starter or flywheel are not meashing together best chance is remove starter and go from their and remove lower transmission covers to check flywheel teeth, if you cant already see them from starter hole.
