i hooked up all the lines and everything for the turbo setup and went for the first start up today, started up no problem idle fine so i went around the block, came back cause it was bogging out some and started going over a check on all the lines and what not, pulled my dip stick out and the oil that i had just put in the night before is now a milky colour, obviously i have a line hooked up wrong im guessing, but i am not sure what line goes to which spot on the turbo. i tried looking online for diagrams but have not found anything big enough that is legible, if someone has a diagram or can tell me which spot the turbo feed and coolant lines go to that would be great.
give me a call at 905 435 3178 im in the whitby area on weekends or ill walk you through it over the phone, im at the shop during the week 416 661 4100 (finish line motorsports) ask for mike
