HEEEEEELP!!! I need advise on unlocking a tape deck in a 1992 Olds Cutlass. ALl the display says is “LOC” and it won’t take any numbers I press. Is there a certain sequence I need to push and is there a code? Where to find it? Thanks
call me ,i’ll tell u
Great! pm me ur number! :naughty:
You sir, are a pimp.
Brian, is your way any different?
ok the very first step doesn’t work…(holding presets 2+3 in) I still get no change of diplay or numbers that i need.
2-4 at the same time,did u hold 2-3 at the same time?
- Press and hold presets 2 and 3 for about 5 to 10 seconds until you
get 3 digits on your display. This is the first 3 of 6 digits you will
need, so write 'em down.
:dunno: dumbestics! I’ll call u buddy
