Help with 01 1.8T Jetta
Driving to school this morning, it had been runnin for 5-10 mins, go to get on thru way shift from 2nd to 3rd aroun 4500 rpm, no loud noises just no power and really severe shaking when the turbo would normally spool. I drove it home later and took off a vacuum lines to see light yellow liquid/mush in there. The CEL is on and flashes while building boost. I don’t have a clue what happened. Any advice?
Cliffs
-Severe shaking while building boost
-Light Yellow liquid/mush in vacuum lines
-CEL is on and flashes while building boost
any mods? Boost gauge?
Can you take pics of said yellow stuff??
where abouts are you located?
Located in tonawanda, i will take pics tomorrow but imagine watered down dijon mustard.
No boost gauge and some mild mods.
3"downpipe to 2.5" Catback APR exhaust
Samco Hose Kit
Forge Inlet Piping
N75 Frequency Valve
93 Tune
eww, like the kind that squirts out of the bottle if you don’t shake it first?
yuck.
p.s.
doesn’t CEL flashing = misfire?
Or is that only on GM cars?
you need coil packs
replace all 4
coil packs or plugs, but the yellow stuff i have no idea
Yes, the kind that comes up if you dont shake it.
Ive been told misfire in one of the coils by three people now.
Any idea what it’s like to replace these?
about 8 minutes of your time, a 10mm socket, and a 5mm allen.
Perfect. Thanks.
