Help with Haltech P1000 Rev Limit settings
So as some of you may recall, earlier I was having some issues with my SR after the last Drift-Ops event. I ended up fixing the main problem, but seemed to create a new one in the process.
I decided to upgrade my P1000’s firmware to v1.09, from 1.06 because I thought I might have had a problem with my ECU, and it might help to put the newest firmware on it. The map I have from my tuner was done in 1.06, but after installing 1.09 it required me to “update” the old map into the new firmware version.
My original Rev Cut was at 6800 RPM, however now it cuts at around 5500 for no apparent reason. It runs fine other than this issue, still pulls hard, etc.
I googled the issue to see if I could find some info that could help me figure out what happened, and came across this:http://forums.haltech.com/viewtopic.php?f=23&t=8095&p=27405
Apparently they changed the way they program the rev limit to go by coolant temp somehow in v1.09. Here’s a screenshot of what my updated 1.06 map rev limiter table looks like atm:
http://img714.imageshack.us/img714/9069/revlimittable.jpg
If someone could tell me what I have to do to fix this issue, it would be greatly appreciated.
Thanks,
Dan.
P.S. My tuner isn’t available at the moment, otherwise I would obviously ask him, :stuck_out_tongue:
If you’re in a pinch, you can send your ECU file to info@u2ndyno.com. I’ll build your table and send it back for upload.
That would be awesome, I’ll send the file your way now. Thanks Dan!
Check your email dude…you’ll be up and running in no time.
Perfect, thanks a ton Dan!
