Hicas/Non Hicas Power Steering Line Fitting
i finally dropped the sr in this week, my car was a hicas but im removing everything, the p/s pump that came with the SR was non-hicas so im using that. when i tried to hook up the p/s line to the pump, the banjo bolt from the non hicas pump is too big to go through the fitting on the high pressure p/s line.
EDIT - FOUND ANSWER, MY P/S PUMP WAS MISSING THE ADAPTER THAT IS NEEDED, this thread can be deleted.
