I purchased a hid kit off jdmpanada for my s14 kouki. i have a coupel questions about the install. the part with the bulb has a plug that goes to the ballast and a + and a - wire. where do the + and - wires go? do i tap them into my oem harness? aswell there is another section of wire that looks like has a relay and some grounding wires, do i use this or do i just use my old harness? thanks for the help. if anybody could sketch up a proper diagram that would be awsome
(it is a h1 kit low beam only)
you should see a wire that has like two fuses together side by side (mine had two fuses )… that one goes to the battery terminal.
on each side of the lights… there’s also a ground… they are black lines w/ the circle metal head thingy… just mount them to any body part…
and pretty much the bigger plug just goes to one of the light plug. that/s it the other ones. just follow the male/female plugs for each light… literally plug and play.
ok the 3 plugs go to the ballast were do the + and - wires go to on this one?
where do these 2 plugs go to because they wont plug into my existing harness? awell as the + and - wires?
u gotta retro fit…
go to the HID group buy page and contact mike or mark… hell fix u up
(no im not telling you to buy a new set… a guy in the forum is PRO at setting these nasty things up… sick to use a bitch to install at times…)
wow yours looks different from mine… I got a bixenon and it’s different from this one… … werid…
the install shouldn’t be a prob.
since you have a kouki, i am not familiar with, Jason(spooolin) has a set of h1 installed on his kouki. He should be able to give you some pointers on what to do about the +/- wires.
oh yeah. don’t touch the bulbs with your fingers.
h1 is very different compare to H4 Bi-xenon ![]()
